RCU Forums - View Single Post - Debate on Lipos. To balance or not?
Old 03-25-2014 | 08:26 AM
  #44
MTK
Originally Posted by hoverlow44
i always check individual cell voltage under load. .5 A
My 2 1/2 cents worth....
I also use 2S LiPos in my airborne set-ups and regulate the voltage to 6 volts.
The batteries come with the balance jack already installed so I tend to use the balancer. Not every time but fairly often. BUT I never charge in the plane. I have mine set-up so the battery sits up just under the canopy so it's simple to reach and remove/reinstall. Just a little forethought is all it takes and I'm sure you can do that too! Most that use LiPos in their airborne set-ups do that.
One other thing I often do is to check voltage after the second and fourth flights. The discharge rate has been extremely consistent so I know within .03-.05 volts how much drop each flight produces. I run my airborne and CDI from the same battery and the 2000 ma gets me 75 minutes of flight time or 5x15 flights
