RCU Forums - View Single Post - Spoileron, Flaperon theory?
Old 10-02-2003 | 03:24 PM
Montague
Default RE: Spoileron, Flaperon theory?
I'm sure there are guys here with more knowledge on this one, but I can say a couple of things:
From my own experience, reflexing the ailerons a tad can sometimes help delay a tip stall, so it's worth trying.
However, I personally think the reason "why" given to you is wrong. I think the help is because the raised ailerons reduce the AOA of the wing slightly, and the effect is more pronounced at the tip, since the ailerons are usually a greater % of wing chord at the tip than the root. So you basically are adding washout when you raise the ailerons.
