RCU Forums - View Single Post - Some maintenance, to engine and airframe
Old 03-26-2014 | 08:50 PM
Recycled Flyer
You may find that Cox engines used hardened steel and consider what you are running the conrod up against - the big end undoubtedly will be steel and the crank pin will be similar.
Can you guarantee enough of a hardness difference to overcome galling?
And what about the extra weight of steel in an engine bigger than an 049?
