RE: Prop fit
The first props that I used with my first airplane needed to be screwed onto the crankshaft. But I had problems with the prop nut coming loose when I started up the engine. Once I got a prop reamer and opened up the hole so that it slid on, I never had a problem with the prop nut.
Kerry
