Originally Posted by
dgxco1
Not to hijack this thread but I have a Tiger II and M-26 made by Tamiya, both have issues with the turret rotation and skipping / stall. No wires binding and I have tried to adjust the gearing a few times but have the same results, I do not see any teeth stripped or stressed?
That gear has a clutch set up. Take it apart and clean all the oil and/or grease from it and CA or epoxy the small gear to the larger gear. Or... just get the Tamiya 6-speed gear set ITEM72005**1200 (my personal suggestion) and use the blue gear(s) from the kit.
I do believe there are 3 to 4 gears in there, enough to fix maybe 2 tanks with the elevation and turret rotation.
Jeff
