Another tip....always do full power run up at start of flying session. I did some experiments that showed that, even when you have a jet cat filter full of air AND mounted horizontally, a full power run up is enough to purge air from filter due to high fuel flow rate through filter. That said, I always employ the measures as noted by Dave W and Harley mentioned above.
