No need to replace the case if it is just the mounting hole that is cracked.
Get a piece of 3.16th ali bar about 1/4 inch wide and drill two holes in it the same distance apart as the engine mount holes.
Now use bolts that are 3/16th longer if required and fit the engine with the bar above so as to clamp the mount to the bearer.
