RCU Forums - View Single Post - Cracked engine mounting
Old 03-28-2014 | 08:38 PM
JohnBuckner's Avatar
JohnBuckner
A new case for a .95AX is a 109 bucks so a little effort at alternative repairs may be called for. Another method I have used in past successfully if you do not want to be limited to pinch type engine mounts is to fabricate two light gage steel sheets in the shape of the mounting lug, Measure and pre drill the two holes then bond the steel sheets one on top and one on the bottom of the mount lug with JB Weld
After cure clean the holes with a drill of the pressed out JB. This works well depending upon how much of a lug is missing around the bolt hole.
John
