RCU Forums - View Single Post - Balancing model
Old 10-02-2003 | 05:41 PM
jrpnde
Default RE: Balancing model
Is it a lot nose heavy or just slightly? A little nose heavy is not bad to start. You are checking with the tank empty? Of course, adding weight is the last resort. But if you must, the LHS sells lead strips that are scored and can be broken into the desired amount of weight. It shouldn't take a lot since you can put it at the very end of the tail.
Is this a new plane or used?
