Originally Posted by
glazier808
Well that door is inaccessible at it sits now. Swamp Ghost I guess you could say is a low rider ATM lol. I wasn't sure if you asked for shots of the crew door as well, so I shot a few. As you can see the rack that the plane sits on is relatively low to the ground.
I had to lay down to get this one.
Casey
That little door to the right is the one that I didnt get a picture of from the inside. It was sitting about that height when I was inside it at Chino in 2012, I think they are using the same stand. It sure took a beating on the belly, all that damage occurred after they pulled it from the swamp, its very fragile from just below mid level down.
