Goldberg Ultimate
Part way into building this and have read a couple items about beefing up the cabane area of the fuse.
I suppose just adding 1/16 ply on the inside where the bolts come through should be good, or is there something else I should think of.
Also, am i to believe that to bolt the lower wing on, the front bolt goes through a hardwood mounting block and plywood, but the rear bolt only goes through the balsa trailing edge???
That seems like a failure in the making.
I know there are a bunch of these planes out there so someone must have an idea.
I got a set of fibreglass landing gear and cowling for it as well. Power will be a pumped OS 12FS.
Any helpful comments would be greatly appreciated.
Thanks to Minnflyer for the drawing on aileron servos.
Helped out alot.
