I'll do that tonight. I had a helper sight up the tube, and he never saw anything glowing. And the temp on the terminal read about 8-12 degrees C. Seems kind of low, and it never really rises. Actually, the outside temp was around 35 degs F. 12 degs C is around 53 degs F so if it's heating at all, it's not getting very hot. One question...is there a glow plug AND an igniter? Two separate types of heat sources? I should also mention I have around 10V available to the turbine. Thanks!
