ORIGINAL: rcpilotjae-RCU
Lucas:
I thought of that (the vent tube trick), but the whole carb is hanging out there in the wind. I was just wondering if that's going to present a problem or not. Sure there's gassers on profiles, I'm just wondering if it's going to present a problem or not and if not how do the guys/gals get around it.
My whole carb sticks out of the cowl on my Giant Stinger and I've never had a problem. I do run a velocity stack though. If your diaphram is pointed directly forward, you will need to block it from the air, or use the vent tube trick.
