Cheers airbrushler! I've been seizing the photo etch! It takes forever but looks nice and because I'm soldering hopefully fairly robust!
Today I've done the rear reflector and been doing the 20T jack. With the voyger PE you have to scratch quite a lot of the jack . I tried to use the hl jack but the main body was the wrong size do I used styrene:
First of the mounts:
With the jack:
Made a start on the jack block:
Unfortunately the styrene supplied is too thick to make the latches so the rest will have to wait till my brass wire arrives.
