Originally Posted by
SyCo_VeNoM
Well the engine I said that broke its brass bushing on the conrod that is actually what happened it hydrolocked(would do it a lot actually), and the roto start that I was using button got jammed(side note I threw the roto starter out a little after that). Also it never would reach proper break in temps with stock settings (it hit like 170 on a 95 degree day after 20 mins...)
If covering the head alone won't get it to heat up, you have to lean the needles down. Those OEM settings are only set to get the engine started. It's often overlooked in manuals so new guys don't always get the right information and their engine's life suffers because of it usually.
I've always had to lean the needles on my engines to get them hot enough when new.
