Originally Posted by
gooseF22
When using the CB200, you have 3 speeds to set in device explorer
1. go to the 1st receiver, and set its speed to auto.. Keep it in EX mode, make sure failsafe is off
2. repeat on 2nd receiver..
3. navigate to CB200 under general settings, and set that value to 17 to 22ms, for analog servos. It is independent of the input speed from the receivers..
All your failsafe values are also set in the Cbox..not the receivers..
CBOX output speed is the one you have to play with to make sure all your servos operate properly..dont mess with the receiver speed
Ok, that worked. But I guess this is true for an RSAT as Satellite. When I use an R3 and need one Servo Output directly from the R3 I will have to switch Failsave on and set 17ms.
I'm programming a glider with 15 Servos and want to use the external Channel 16 for my WStech Vario.
Regards, Walter
