Originally Posted by
Walo
Ok, that worked. But I guess this is true for an RSAT as Satellite. When I use an R3 and need one Servo Output directly from the R3 I will have to switch Failsave on and set 17ms.
I'm programming a glider with 15 Servos and want to use the external Channel 16 for my WStech Vario.
Regards, Walter
Correct sir.. except do not enable failsafe in the receiver... put some function on the 16th channel you can live without if it were to blank out for a couple secs.. Failsafe should only be set up in the Cbox, on a CB200 setup.. not in the receivers... very important..
If you enable failsafe in any SAT receivers, in any setup, you could have the receivers telling lies to the xbox or servo driver rx, and it would not know it.. This is mega important!!
