Originally Posted by
LA jetguy
Walo... Yes.. RSat & CB200 is limited to 15 connection... R3 & CB200 can have 16 connection... one of the R3 output pins will act as the 16 connection. In that case failsafe and 17ms needed for that R3
also correct sir
However, you must set BOTH receivers to 16 channel output, not 15.. and you must enable 14/15 for servo output in the Cbox device explorer.. Recognize that there could be a little latency on the 16th channel since it drives during the gap time..
