Yesterday at the field the K100G would not start. ECU error message Ignition Fail.
Here are my parameters in the ECU
Pump Start Parameters = Auto+2
Pump Start Ramp = 006
Glow Plug power = 7.2v
Low Battery Volts 7.02
Starter power at Ignition = 090
at Fuel range = 130
RPM 100% Starter Power=22K
RPM OFF Starter = 30K
RPM to reconnect = 28K
RPM ignition K= 5K
Pump PW Ignition = 26 (Notice Flame, I just change it to 22
Engine Min flow currently is 30%
EGT Ends Preheat = 0072
RPM Preheat k = 5k
RPM Fuel Ramp = 9K
Preheat Fuel = 30%
Ignition time out 30 sec
After 15 flights
ECU error message Ignition Fail,
Any suggestion ? Or do I need to send it in for service
