Originally Posted by
gooseF22
As I was reading more about the new Vario2 system, I see that it can be used as a logical switch detector.. cool..
It has 2 servo jacks on it that can detect signal to ground logic.. Ie a micro switch closing or opening. Hmmm use your imagination..
Is the canopy closed?
Is the nose gear down?
and with the upcoming telemetry actions, you can have the transmitter do something based on it..
maybe a true sequencer that is based on actions instead of timing..
doors open _switchA open.......
Gear down - switch B closed.....
Doors close - switch A closed..
transmitter says "gear down and locked your majesty, you may land now"
All very cool but you should also be able to do all that by assigning otherwise unused receiver channel(s) as a digital input(s), right?
