CONTROL THROW MEASUREMENT U CAN DO 60??
Where on the control surface do you measure for the control throws ????
The ailerons are much wider on the inboard side and would give you a higher throw.
If I measure from the outer tip the measurement is much less. Which is the right way??????????
Thank You,
Larry
