Originally Posted by
EXT2Rob
The DTX Element system "by Castle" IS 3S capable. Tho I would gear it down if you did so. A light, 2wd car like this is car-RAZY fast, hard to control, and good only for speed runs pretty much. But then a 3900kv.....might not be too nutz on 3S if geared right. Go down a few teeth on the pinion.
OK, I don't have the element system tho. not labeled that anyway. just has a big D and says duratrax on it. it does look basically like a sidewinder tho.
