Lol, what are you waiting for? Why don't you do it yourself?
I just got 2 of these truggies myself and plan on converting the one and using the other one for spares and the center diff for a Genesis conversion.
I'll post pics sometime soon.
Basically:
1 Vorza motor mount or any other mount you prefer depending on the motor you will use - I'll be mounting the motor on the opposite side to the servo
1-2 battery boxes (again you can take Vorza boxes or some other) - one on each side of the support brace at the rear end of the truggy
1 ESC - mounted same side as motor but at the rear.
Drill some holes, countersink the holes, mount your stuff and off you go...
Reason I will be doing it this way is to make the truggy front heavy instead of all the weight at the rear.
I'm planning on only using one box for now. The size allows me to stand up 2x2S batteries. If I do go 6S, then I'll mount the 2nd battery box towards the rear on the motor side and mount the ESC on top of the servo.
