RCU Forums - View Single Post - CONTROL THROW MEASUREMENT U CAN DO 60??
Old 10-03-2003 | 03:31 AM
EXCAP232
My Feedback: (12)
Default RE: CONTROL THROW MEASUREMENT U CAN DO 60??
ORIGINAL: chrome350
Where on the control surface do you measure for the control throws ????
The ailerons are much wider on the inboard side and would give you a higher throw.
If I measure from the outer tip the measurement is much less. Which is the right way??????????
Thank You,
Larry
Measure at the widest part of the control surface. Another method is to use a throw meter which measures in degrees. I perfer the meter and feel that it is more precise.
EXCAP232
