Originally Posted by
rcpete347
Well I am lost for words, tonight I powered up the Futura and all works, as it did yesturday morning. The only difference is the turbine was running when the PB started to fail.
Rcpete
Pete,
Does this engine use a single channel ? or is there an aux ? I had an issue once with a Powerbox (non srs ) and a JetCat ECU. In my case I was using the throttle and aux channels to the ECU both going through the power box. For whatever reason, when powered on, this created a loop/short somewhere and cables would start to fry. I ended up connecting these 2 channels directly to my receiver and never had the problem again. I spoke to Bob Wilcox about this and he saw no way there would be a short/loop anywhere based on the set up, but it was an anomaly that almost caused a whole plane to go up on fire if i had not been looking at the cables . Powerbox and ECU both checked out fine. .. go figure.
Voy
