Originally Posted by
Dave Harmon
Hi Joe....don't ream the adaptor.
Mount the Advance motor, connect it up and run it slowly while holding a strip of 400 wet/dry with some oil to take the shaft down just a bit.
It will not take much....keep trying to fit the adaptor as you go but clean the shaft before you trial fit it.
The adaptor does not want to be loose....make it a just-right fit.
Dave
You guys just ruined my day. I recently bought a Falcon spinner for a Neu with an 8 to10 mm prop adapter. Am I going to be able to ream the spinner adapter to 10mm? Do they sell a 10mm adapter?
By the way my 8mm reamers fit perfectly in the Falcon supplied adapter.
Jim O
