Tom...thanks for the comments...your input helps greatly. The plane is beautiful by the way... I am doing everything you have mentioned. Everything. The paint I am spraying is setting quickly...my thinning is almost yours probably 50/50. I am getting acceptable coverage, no runs, the only problem I am having is the paint lifting under the 3M tape. Any masking tape has no effect on the white...I am getting ready to tape over the red just painted today and will shoot yellow hopefully with your 40/60 ratio and then we will see if the red and white hang together and both hold to the primer. But thanks for your comments, I just wish I was not on this forum with this problem.
