RAF, the green poly fine line tape is great for hard edges and gentler curves. The scotch 3m tape ID is #218, its what I am using with the flite metal. The blue vinyl is best for tighter radius. The paper blue painters tape you should use ONLY to add surface to lay your protective covering for over spray Both can be picked up at well-stocked auto paint supply stores. Cheers bro!
Oh yeah, I will be retired and back in Cali end of June
