RCU Forums - View Single Post - FLy Eagle Jet Models
Old 04-15-2014 | 11:49 PM
  #2127
Damo260's Avatar
Damo260
Originally Posted by vincezam
Hi,
The wings alone are 4.2Kg for both. If I remove all the installed equipment, I will still have remaining 12.6Kg for the airframe plus UC, trust tube and empty fuel tanks.
I have installed the following equipment:
[TABLE="width: 547"]
[TR]
[TD]Qty
[/TD]
[TD][/TD]
[TD]grams
[/TD]
[/TR]
[TR]
[TD]1
[/TD]
[TD]Wren 160 turbine
[/TD]
[TD="align: right"]1700
[/TD]
[/TR]
[TR]
[TD]8
[/TD]
[TD]8x Savox SC1256TG Servos
[/TD]
[TD="align: right"]419.2
[/TD]
[/TR]
[TR]
[TD]2
[/TD]
[TD]Futaba R7008SB receivers
[/TD]
[TD="align: right"]21.8
[/TD]
[/TR]
[TR]
[TD]1
[/TD]
[TD]Powerbox Cockpit SRS
[/TD]
[TD="align: right"]130
[/TD]
[/TR]
[TR]
[TD]1
[/TD]
[TD]Powerbox Gyro SRS
[/TD]
[TD="align: right"]50
[/TD]
[/TR]
[TR]
[TD]2
[/TD]
[TD]Lipo 2200mah
[/TD]
[TD="align: right"]266
[/TD]
[/TR]
[TR]
[TD]1
[/TD]
[TD]Lipo 33000mah
[/TD]
[TD="align: right"]183
[/TD]
[/TR]
[TR]
[TD]1
[/TD]
[TD]Jetronic Break Valve
[/TD]
[TD="align: right"]32
[/TD]
[/TR]
[TR]
[TD]3
[/TD]
[TD]Jetronic Dual Valve
[/TD]
[TD="align: right"]96
[/TD]
[/TR]
[TR]
[TD]1
[/TD]
[TD]UAT with fuel
[/TD]
[TD="align: right"]200
[/TD]
[/TR]
[TR]
[TD]17.5
[/TD]
[TD]22awg servo wire
[/TD]
[TD="align: right"]262.5
[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Total equipment weight
[/TD]
[TD="align: right"]3360.5
[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Airframe, Trust tube, UC, and 3x empty fuel tanks weight
[/TD]
[TD="align: right"]12639.5
[/TD]
[/TR]
[TR]
[TD]2
[/TD]
[TD]Wings including UC but no lights
[/TD]
[TD="align: right"]4200
[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Fuselage including cockpit no pilot
[/TD]
[TD="align: right"]8439.5
[/TD]
[/TR]
[/TABLE]
You said you had the Viper S I don't think you need a 160 in it and I don't think trust tube rated for a 160. I think it would fly on 22 lb turbine you would save 400grams
Damo
