acdii, I use the very inexpensive automotive touch up guns that Harbor Freight sells. Usually under $20. Depending on the color i'm spraying at the time, i cut the paint at least by 50% with thinner. I spray around 30lbs at the gun. On occasion, i use an even less expensive Badger airbrush for areas that dont require more paint than is in one bottle....Gene
