[h=2]With a little research I could find this info:
Specifications (F/A-18C/D)
[edit][/h]
Data from U.S. Navy fact file,[SUP][110][/SUP] Frawley Directory,[SUP][111][/SUP] Great Book[SUP][112][/SUP]
General characteristics
- Crew: F/A-18C: 1, F/A-18D: 2 (pilot and weapons system officer)
- Length: 56 ft (17.1 m)
- Wingspan: 40 ft (12.3 m)
- Height: 15 ft 4 in (4.7 m)
- Wing area: 400 ft² (38 m²)
- Airfoil: NACA 65A005 mod root, 65A003.5 mod tip
- Empty weight: 23,000 lb (10,400 kg)
- Loaded weight: 36,970 lb (16,770 kg)
- Max. takeoff weight: 51,900 lb (23,500 kg)
- Powerplant: 2 × General Electric F404-GE-402 turbofans
- Dry thrust: 11,000 lbf (48.9 kN) each
- Thrust with afterburner: 17,750 lbf (79.2 kN) each
- Fuel capacity: 10,860 lb (4,926 kg) internally[SUP][113][/SUP]
Performance
- Maximum speed:
- High altitude: Mach 1.8 (1,190 mph, 1,915 km/h) at 40,000 ft (12,190 m)
- Low altitude: Mach 1.2 (915 mph, 1,473 km/h)[SUP][114][/SUP]
- Range: 1,089 nmi (1,250 miles, 2,000 km) with only two AIM-9s
- Combat radius: 400 nmi (460 mi, 740 km) on air-air mission
- Ferry range: 1,800 nmi (2,070 mi, 3,330 km)
- Service ceiling: 50,000 ft (15,240 m)
- Rate of climb: 50,000 ft/min (254 m/s)
- Wing loading: 93 lb/ft² (454 kg/m²)
- Thrust/weight: 0.96 (1.13 with loaded weight & 50% internal fuel)
Armament
Avionics
- Hughes APG-73 radar
- ROVER (Remotely Operated Video Enhanced Receiver) antenna for use by US Navy's F/A-18C strike fighter squadrons
