Looks good! I am glad to see that you had to re-work the top of your cowl. Not because you had to do the work, but because I did it the same way, and mine needed re-working too. And since your work is way above mine, I feel that I got it correct. The bottom of my V11 cowl is different than your DVII. Were 2 parts enough to do the job for you? Again.. looks good!
