robarts retract binding
I am having problems getting the gear to retract. replaced with new actuator new pin and brass fitting plus new trunion. the actuator moves up approx 1/4 " and stops. are there any adjustments I should check. Could the problem be with the grove when in the gear down lock position. I did break the trunion during hard landing. AC IS THE TOP FLIGHT 86.5 SUPER MARINE SPITFIRE.
THANKS FRANK
