RCU Forums - View Single Post - Engine vent line question
Old 04-21-2014 | 03:54 AM
Rodney
Years ago none of the model engines used a pressure line. It was not until the late 60's that it became the normal set up. Most 2 strokes will still run reasonably well without a pressure line, it does take a change in needle valve setting however. I also have some early 4 strokes that did not use a pressure line and, all my newer ones will run without the pressure line connected, just not as well under all circumstances.
