RE: Building Error.. Will it fly????
As long as the wings and tail feathers are straight, that is, no twisting warps, the difference you mention shouldn't be enough to affect the flying.
Any effects as a result of the error will probably be trimmed out when you first fly it.
Incidentally, on your first flight be sure to set the aileron travel as low as 40% rate or lower, or you run the risk of screwing it into the ground faster than you can blink!
Good luck and have fun. It's a great plane!
-David C.
