RCU Forums - View Single Post - Paint
Thread: Paint
Old 04-23-2014 | 04:29 AM
TomCrump's Avatar
TomCrump
Originally Posted by bobbailey
Was wondering re paints and primer. I used a white primer on wheels that contains toluene(sp). Then tried krylon paint on top. it reacted and bubbled. question is I have primed the cowl with same primer and don't want it to bubble. Should I look for a paint that also has the the Toulene in it? apparently it has a base not compatible with the water base krylon. I saw rustoleum that also has the same ingredient. Thx
How long did you let the primer dry, before you applied your paint ?
