Originally Posted by
SeaHawk-RCU
Hello Ed,
I am working on the fuselage of the new Sea Vixen schemed Falcon. I have never used a "cockpit tub" in previous models and was wondering how you used the one you modeled ours on. Do you attach the tub to the fuselage, route the battery charging, refueling etc through the tub floor and then have the canopy removable or do you make a single unit out of the canopy and tub and have the whole thing removable for access? I suppose one do do either but I was wondering what you do on your aircraft.
I steered well clear of the "up/down thrust" debate. It is a matter of correctness vs common usage. My pet grumble is the use of "trailing link" for a trailing arm undercarriage. Another that comes to mind is the electric crowd's use of KV as revs per volt when it is really thousand revs/volt. "700KV" would be one hell of a high revving electric motor where they obviously mean 700 revolutions per volt. Ahh well,,, it is a funny world.
Cheers Ed
Col
Hello Ed:
With regards to the cockpit tub, here is a link to how I mounted my cockpit tub to the canopy. See post #164
http://www.rcgroups.com/forums/showt...095652&page=11
Also, my canopy securing method is also discussed earlier in the thread. I believe it is post # 74
http://www.rcgroups.com/forums/showt...2095652&page=5
Let me know if I can be of further assistance.
Ed
