RCU Forums - View Single Post - Is it worth adding a gyro?
Old 04-27-2014 | 08:33 PM
Gra55h0pper's Avatar
Gra55h0pper
Originally Posted by mikes68charger
Can you guys post links of the ones you use. My fear is the gyro not handling the servo load. Ie the anos needed for the larger jet 200oz type servos
You can run (some of) the power directly to the servos, rather than through the gyro itself.
On my iGyro, for two JR8911 elevator servos I separated out the power from the signal, having the power supplied directly from a JR1222 PowerSafe receiver output, where the signal is coming from the iGyro itself. This prevents the iGyro from possibly being overloaded.
