I expect that most gyros have a common power bus across the board so handling the load should not be a problem, I think that servo's current draw is so low you'd struggle to fry the gyro with it unless maybe you have a giant jet with multiple servos per surface.
As I understand it from demon in this scenario you could potentially use more than one gyro to handle the load.
