Originally Posted by
BlueBus320
From my understanding, if the 3 axis gyro has an inflight failure you will loose elev, rudd, & ailerons.. There is no recovery procedure for that! For me it is worth it to fly a little less stable jet for 20 years then to have a perfectly stable-flying jet possibly fail after 100 (arbitrary number) flights or so due to a gyro. With all that being said, I LOVE the 3 axis gyro concept! We also need someone to continue testing them so they will advance & hopefully become bullet-proof one day, so THANK YOU gyro flyers, keep up the great work! They are very pleasing to watch.
actually there is.. with the demon, you just zero the gain, and its a pass thru.. if it ever failed..
I am a convert.. Im flying the demon cortex in all my toys.. You should see it turn off the wind in smaller stuff.. There are also a lot of jets flying them now..
