The point to remember is how much or how little detail work you intend doing, if you are going to leave it pretty much as it comes then I would suggest the all metal Tank is the way to go BUT if you are planning to do a fair amount of detail work to give it that original touch then plastic is much easier to work with, so I would then suggest a metal hull with a plastic top. shaun
