RCU Forums - View Single Post - Sebart Miss Wind S 50E
Old 04-29-2014 | 11:19 AM
  #552
martin1962
Hi Thomas
I would be tempted to take a small peice from behind the wing and when its sits in properly into the sadle is should sit tight upto the former. If you alter the front you may find that the wing bolt will not line up and you then have to change that ,then the top and bottom wing supports wont fit and then they need changing and so it goes on and on. Mine is very tight to get it place..
Martin
