Originally Posted by
DrYankum
How would one use a 3 axis gyro, if one of the uses is for nose wheel? Eliminate the rudder? Seems like a compromise. Get a separate single axis for the nose wheel? Seems like an added expense
The Cortex has 5 Input/Outputs so you can stabilize the steering independent of the rudder ie: two separate channels
