RCU Forums - View Single Post - Is it worth adding a gyro?
Old 04-29-2014 | 11:34 AM
  #56
gonzalom's Avatar
gonzalom
Originally Posted by Gonzalo38
Gonzalo:
Thanks for sharing your experience. I also using the iGyro in most of my planes and I'm really liking it. This weekend I need to program the one I just installed in my Skymaster A-10.
Any differences between the iGyro and the Cortex in terms of performance ? I have two older planes that could benefit of a gyro but I can't install the IGyro so that's why I'm thinking on the Cortex. Also interested on your review of the Guardian after you try it.
Gonzalo, the Cortex works very very well and simple to setup. If I don't need some serious power distribution on my jets the Cortex is a very good choice! I setup my jets with flight mode on the flap switch and the Cortex setup to be at 30% gain at flying mode, 40% gain on take off with one point flap and 70% gain for landing 2 point flap. I do fly using rate mode only an not HH. Those numbers are perfect to start and you can adjust later to what you like. the PBS Royal SRS does the gain automatically due to the GPS onboard. By the way I just upgrade my PB Royals SRS to use the new PB GPS 2. Give me a call if you have any questions.
Gonzalo
