RCU Forums - View Single Post - Sebart Miss Wind S 50E
Old 04-29-2014 | 11:37 AM
  #553
thnilsen's Avatar
thnilsen
Originally Posted by martin1962
Hi Thomas
I would be tempted to take a small peice from behind the wing and when its sits in properly into the sadle is should sit tight upto the former. If you alter the front you may find that the wing bolt will not line up and you then have to change that ,then the top and bottom wing supports wont fit and then they need changing and so it goes on and on. Mine is very tight to get it place..
Martin
The problem is that the wing bolt does not line up as it is now since the bolt hole in the wing is about 1.5mm too far behind due to the skew former. I could always enlarge the bolt hole in the wing 1.5mm forwards to make it align with the fuselage nut, but that would also mean that the wing would be sitting 1.5mm behind where it is supposed to be. I'm worried that this difference will make the alignment of the struts and upper wing wrong. It might also impact the lower wing incidence. By removing some balsa material on the front left hand side of the wing marked by the red ring in the picture i should be able to make it fit nicely and snug where it is supposed to with the fuselage.
