Originally Posted by
Bob_B
The Cortex has 5 Input/Outputs so you can stabilize the steering independent of the rudder ie: two separate channels
But then you would be sacrificing either an extra elevator or aileron function (i.e. one of them would require a Y harness, assuming that you have two elevator servos)
Hey Bob, do you have both the I Gyro and the Cortex?
Can you provide any sort of performance comparison?
I know that the I Gyro has a GPS feature for adjusting the gain based on flight speed, how does the Cortex handle this? Is transmitter mixing the only option?
I guess I will need your help again with the 12FG
