Originally Posted by
Granpooba
Ditto !
Very correct in most cases. However, when the venture is inside a cowl, things can change due to the way the air flow is directed with the internal baffles and how close the cowl skins are to the venture so you may have to experiment a bit there to get the best angle. If out in the open it is usually best to have the slant to the rear or have no slant on the venture at all (square cut ).
