[QUOTE=Jetdesign;11793756]There is some interesting stuff in this thread. My thought is that most modern full scale jets are designed with computer stabilization in mind. I am pretty much 100% opposed to a gyro in almost any model airplane, except for jets and particularly ones where the full scale versions fly using some type of fly-by-wire. I fly in precision aerobatics contests so I am all-for full pilot control of an aircraft. But if an aircraft is designed with known inherent instability traits it seems crazy to me to hold it against anyone for trying a gyro.
In flying IMAC or precision aerobatics, do you not consider the down elevator you have programmed into idle at down lines, or rudder and aileron mixes for knife edge to be full pilot control.
For that matter ...are expo and dual rates full pilot control?
I am dating myself, but when I started flying there was no servo reversing, expo or dual rates. I fly IMAC as well as turbine jets now, and I agree that gyros in precision aerobatics should not be allowed,but it is disingenuous to say that you are flying with direct pilot control. Gyros have a use in model airplanes, whether the full size used some sort of stabilization or not
