Originally Posted by
BullardRM
Thanks for all the inputs. Greatly appreciated. I think I'm sold on the DB system for my Tipo. I also plan to use the two servo set up for ease of assembly. Thanks again.
Now that I have tried both methods I can tell you that two servos is the ONLY way to go. I'd also suggest a separate steering servo slaved to your rudder with a mix. Makes trimming the steering a breeze and allows you to turn the servo off when the retract switch is "up."
