RCU Forums - View Single Post - Engine input for contest
Old 05-02-2014 | 09:14 AM
  #34
jester_s1
Moderator
The gains from removing the baffle depend on the RPM you are running. The higher the RPM, the more gain you get. In my TT .46 Pro, which is essentially a copy of the OS .46 FX, I was running 14,100 on the ground and got to 14,300 by removing the baffle in my Kaos. That's with a 10x6 prop running 10% fuel. Watching the plane fly, I think the gains are actually higher in the air because the engine unloads a lot. So I think it's reasonable to expect 300 RPM in actual flight. With your planes, I would expect more improvement than that. So as combatpigg said, it's not a stupendous gain, but it is a gain and it's free. With more heavily propped engines on draggier planes, it doesn't help at all. I tested the same engine on the ground with an 11x6 prop and actually lost RPM.
